drive oil reservoir bravo >
Old 06-07-2006 | 07:52 PM
jeff32's Avatar
Default drive oil reservoir bravo
drive oil keeps coming out of oil reservoir by cap when rpm goes over 3000. Got the drive tested today and holds 12 pounds all day long. no water in oil. Merc dealer says 2 options: too much vibration on engine should relocate tank, or change the cap. What do you think is my solution or problem ?
jeff32 is offline
Old 06-07-2006 | 08:44 PM
Default Re: drive oil reservoir bravo
I think I read some others having this problem, I think they fixed it with a billet o-ring cap you can buy. Maybe try trick marine
rdp145 is offline
Old 06-07-2006 | 08:59 PM
GOODT's Avatar
from exp ( 25 yrs building drives) its a sign that its over heating, most of the time from a bad brearing, get it checked out by someone that knows what they are doing.....
the lube gets hot expands blow out where the weakest point is
GOODT is offline
Old 06-07-2006 | 09:29 PM
Vinny P's Avatar
I hate the winter!!
I would like to add that gear lube expands when it gets hot. How much lube is in the bottle when the drive is cold? If you put too much in, it may spill out when hot.
Vinny P is offline
Old 06-07-2006 | 11:02 PM
hunster's Avatar
I had a similar problem. Had a cap that leaked , had to buy the whole resevior. Other drive had a bad seal. Boat smelled like gear oil all the time. My friends re-named it the valdez!
hunster is offline
Old 06-07-2006 | 11:39 PM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
If the drive is too hot you may need a drive shower. I can get you one if you need it.. Jamie / lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
NickOTeen
8
07-25-2005 03:31 PM
OkieTunnel
16
08-15-2004 08:49 PM
Hot Boat
5
01-09-2003 04:18 PM
rws
3
06-20-2002 10:09 AM
candyman35
1
06-03-2002 07:28 AM
