How long to wait on 5200 before use. >
Old 06-07-2006 | 10:17 PM
buck183's Avatar
Default How long to wait on 5200 before use.
I need to know how long I have to wait to introduce 5200 to water after using it. Does it need a certain amount of set time prior to use? Can I just wait a couple of hours and run with it?
Buck
buck183 is offline
Old 06-07-2006 | 10:28 PM
vandeano's Avatar
Default Re: How long to wait on 5200 before use.
I think your good to go. If Im not mistaken, it cures with water. But dont take my word on it
vandeano is offline
Old 06-08-2006 | 08:31 AM
Chris288's Avatar
if I remember fast cure is 24 hours slow cure is 7 days ....
Chris288 is offline
Old 06-08-2006 | 01:22 PM
fund razor's Avatar
Buck
You will probably be ok, but I always prefer to give 5200 a couple days if below the waterline as a sealer. Above the waterline as a bedding compound, (hatch etc.) a few hours is probably sufficient.
fund razor is offline
Old 06-08-2006 | 09:27 PM
Buck
It depends, there is a 5200 normal cure, which sets up in 24 hours and cures in 7 days, or a 5200 fast cure which is a much better choice, but harder to find. The label pretty much spells it out. If you don't give it enough time, it will ooze out, run, and drip.
LT1GMC is offline
Old 06-09-2006 | 09:58 AM
eyezlee's Avatar
Did you buy a boat? What the hell are you doing?
eyezlee is offline
Old 06-09-2006 | 03:16 PM
bowtie's Avatar
If you want to put it in the water right away I believe you want 4200. Boat Life is also good it will cure if wet.
bowtie is offline
Old 06-09-2006 | 04:27 PM
BigSilverCat's Avatar
Buck
if you used it to glue your wig to your head I would wait at least two hours before swimming, and if you glued your strapon back together you dont need to wait, short stroking it wont break the glue.
BigSilverCat is offline
David Stotz
Do It Yourself, Boating on a Budget
13
03-19-2008 07:17 PM
zx14
02-15-2008 03:13 PM
rv
11-17-2005 06:29 PM
Dregsz
52
08-05-2005 11:41 AM
Raypanic
Powerquest
11
02-03-2002 12:22 PM
