pressure relief valve
most of the time you see pressure relief valves at the strainer . can i install them at the item i am trying to protect ? boat has 2 bbc would like to run 1 valve at each superchiller and one valve at each intake not at the stainers so when i see dump i know i have pressure at that point . my eng. dump at exaust intercoolers dump right on drives
Wobble is 100% right always give full flow to the coolers, in the case of raw cooling dump the overage before the engine that will help to keep the edges of the head gaskets from weeping. On closed cooling I feel it is good to dump it just before the exchanger water at 30 psi will cool most any setup. I have a BravoX with Hi&Lo pickups I have had leakage at both my strainer and at the exchanger end caps, my boat will not make the speeds that can get the pressure way up but still high enough to be a pain at times.
Phil
Phil
Thanks Guys Will Run #12 Into Intercooler Front With Relief Valve On Front Two #10 Lines Out The Back Of Intercooler Onto Top Of Drive Same On Both Eng. Will Also Put Relief Valve At Raw Water Pump Inlet On Both Motors
