what prop do I need >
what prop do I need
what prop do I need
Old 06-28-2006 | 09:42 PM
cosmic12's Avatar
Default what prop do I need
I have a 2006 28ft Active Thunder with a 525 w ITS xr drive. I am running a stock outa the bos 26 bravo 4 blade . 69 mph @ 4900 rpms I do have corsa mufflers and am trying to make a change there. I know there is a lot more in this what do you think?
cosmic12 is offline
Old 06-29-2006 | 12:58 PM
Wild Card 09's Avatar
the Flightmaster
Default Re: what prop do I need
The easy answer is go to a labbed bravo to get your revs up. But the 525 should be pushing you faster anyway. How heavy is your boat?
My 25 Outlaw with 2006 525, Imco ext box and XR currently showed a best on the GPS 78.9 mph @ 5300 rpm with 11 hours on it. Labbed Bravo 28 works for me. I did try an unlabbed 26" Maximus five blade, though and it swallowed at least the last 50 hp. The boat only ran 73 @ 5000, I think. How high is your drive mounted? I reckon that this is the key with an ext box (ITS). With the drive trimmed down until the cavitiaion plate is parallel to the hull /pad, measure the vertical distance between the two. Mine has 4 1/3".
Wild Card 09 is offline
Old 06-29-2006 | 06:14 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Your efficientcy is good enough to accept Lab Finishing the propeller. You could see 2-3 mph in the WOT range.
[email protected]
bbladesprops is offline
Old 06-29-2006 | 07:37 PM
cosmic12's Avatar
just lab finishing? you talking on the 26? thats all I can expect? a different wheel will not help?
cosmic12 is offline
Sick Stinger
Velocity
9
02-07-2008 11:39 AM
FlyFast
1
08-06-2004 10:22 AM
boatinbill
07-26-2002 09:58 AM
MIKEHTMSR24
07-22-2002 03:18 PM
MIKEHTMSR24
0
07-22-2002 01:40 PM
