Seawater routing? >
Seawater routing?
Seawater routing?
Old 07-05-2006 | 01:15 AM
2112's Avatar
Default Seawater routing?
I have two oversized heat exhangers. One for Oil (3"x18") and one for coolant (5"x24"). Using 1 1/4" hose through a Eickart sea pump pulling though a bravo XR should I be running through the coolant exhanger first (temp @ 170) before going through the Oil exchanger which is thermostatically set to open at 212 degrees? Or is the flow enough that it doesn't matter which one comes first?
My thinking is incrementally step up in temps or the Oil temp will overheat the coolant when it opens up.
2112 is offline
Old 07-05-2006 | 04:49 PM
monstaaa's Avatar
Default Re: Seawater routing?
typically thru oil cooler first, then heat exchanger.
monstaaa is offline
Old 07-06-2006 | 01:02 AM
2112's Avatar
That is how I had it first, then started thinking that when the oil thermostat opens up it will reduce the cooling capacity of the "radiator".
Can you elaborate?
2112 is offline
Old 07-06-2006 | 06:22 AM
GOODT's Avatar
oil cooler first it the typical set up,oil also help cool the mtr
GOODT is offline
randy carlson
0
05-09-2008 07:54 AM
nordic95
8
03-07-2006 03:45 PM
johnnyboatman
18
12-21-2005 05:50 PM
plumbers crack
7
01-02-2005 11:02 AM
CB
4
08-14-2002 11:50 PM
