Bravo XR drive
Originally Posted by seahawk
What is the life expectancy of a Bravo XR.
When should it be serviced?
What parts break?
How do you make it last?
What parts break?
About 1 really big launch and bad re-entry.
Good maintenance practice is replacing drive fluid every 20-40 hours depending on use. Pull the drive and lube the U-joints and check alignment at least once or twice a season.
Upper gears, lower gears, verticle shafts, cone clutches, U-joints.
Leave the boat on the trailer. (Seriously, baby it out of the hole, and go easy in rough water.)
I had problems until I started using amzoil gear lube in the drives and every spring remove the drives and bring them to the shop have them taken apart. Bring the gears and shafts to a machine shop and have the parts magnafluxed for cracks and just replace the bad parts before they explode. Much cheaper and dependable.
Ed
Ed
Originally Posted by racer-x6
Check with Marc at Bam Marine He will hook you up
If the drive did'ent break and you took it in to have rebuilt (serviced/gone thru) what would that typicaly cost.
do you mean dissasemble clean, inspect and reseale ????
approx 400.00 for upper 400.00 for lower + parts
Should these parts just be replaced every year as preventative maintenance???
