Excessive blowby >
Excessive blowby
Excessive blowby
Old 07-26-2006 | 11:33 AM
Default Excessive blowby
Has anyone running a blower ever blew out their intake gaskets? I'm hoping thats what happend to me. After a hard run this weekend i'm blowing oil out my breather when I run hard. It also has a very slight miss now.
kennyo is offline
Old 07-26-2006 | 12:32 PM
SB
Default Re: Excessive blowby
Could be a dead cylinder - bring a compression tester and/or leakdown tester.
SB is offline
Old 07-26-2006 | 02:16 PM
Wobble's Avatar
SORE MEMBER
Compression test then a leakdown test will tell the story, blowing oil consistently is from excessive crankcase pressure.
That is either from too small or badly designed breathers, but more likely from a problem with the rings or a piston.
Blowing out an intake gasket is a small possibility, not likely with most marine blower setups.
Wobble is offline
Old 07-27-2006 | 06:55 PM
thunderusone's Avatar
I think that it is directly related to your BIG FAT RIGHT HAND!!
thunderusone is offline
Old 07-27-2006 | 06:58 PM
Seriously, it is probably either a burnt piston or a bent or "tuliped" valve due to heat. Intake gaskets dont blow....either it got lean or you had too much timing or both.
Old 07-27-2006 | 11:40 PM
Grog's Avatar
Kennyo -
Don't tear your motor down just yet. I put a Whipplecharger on a stock 502 and had serious blowby. Sometimes, the dipstick would blow out of its tube. Since then I had the motor rebuilt (it's a long story) and still get some blowby after a long hard run.
Your breather setup is key. Hopefully you are not getting water in your oil. That is a sign of another problem.
Grog is offline
ActiveThunder
Active Thunder
81
08-06-2010 01:04 PM
Naughty Kitty
45
08-05-2008 06:56 AM
gtrust
4
08-12-2004 01:20 PM
HiPerf2000
11
04-16-2004 06:25 PM
gofastpilot
8
07-23-2003 10:53 AM
