carbed hp500's run rich >
Old 08-03-2006 | 01:15 AM
miamioffshore's Avatar
Default carbed hp500's run rich
my 1999 carbed hp500's are running rich. I changed out the plugs and still no difference. Tried to play with the carb adjustment screws a little but I dont really know what I'm doing there. how should I troubleshoot this?
miamioffshore is offline
Old 08-03-2006 | 03:26 AM
Default Re: carbed hp500's run rich
Running rich when????? All the time??? at idle????
Could be a powervalve or float adjustment.
What fuel do you run. Run 87 octane. It will burn the cleanest and most completely.
Griff is offline
Old 08-03-2006 | 06:56 AM
Canada Jeff's Avatar
Buddy of mine has the same engine. He has over 400 hours on it, and has had to rebuild the carb twice. You should look into that! How many hours on yours?
Canada Jeff is offline
Old 08-10-2006 | 03:55 PM
Running rich at idle, I changed out the plugs and they're still running rich. At speed they're sounding good.
Old 08-10-2006 | 04:38 PM
BajaRunner's Avatar
you have to jet for wide open, so they usually run a little rich at idle. You do have to rebuild them every once in awhile though. I had laz at mesa balancing do mine. when i got them back, i put it on the dyno and the a/f ratios were perfect.
BajaRunner is offline
Old 08-10-2006 | 10:39 PM
If its only rich at idle then its probably one of a 3 things.
Adjust air bleed screws--the 4 little ones
Bad powervalve---only has 1 inside the front fuel bowl
The float level needs adjusted.
Griff is offline
Old 08-11-2006 | 06:17 AM
SB
Totally agree, but would like to add one thing.
Air bleeds may need a good cleaning out. These should be cleaned out with carb cleaner atleast a few times a year. Only takes a minute or two.
SB is offline
ActiveFun
2
10-09-2008 04:05 PM
Velocity Tom
05-23-2007 06:02 AM
ActiveFun
Fountain
1
06-01-2006 08:50 PM
AugiePensa
OPA/The Jersey Boyz
26
06-19-2005 08:58 PM
jbrauer
08-18-2003 08:35 PM
