Twin I/O Power Steering units >
Old 08-06-2006 | 01:31 PM
JShoup's Avatar
Default Twin I/O Power Steering units
I need your help! How do I plumb power steering on each motor? I've already done it but, I have fluid shooting out of the second resivoir when only one motor is running. Is the only way to plumb this is to have just one resivor??
Thanks for your help
Jud Shoup
(970) 376-3704
Attached Thumbnails Twin I/O Power Steering units-resized-drives.jpg
JShoup is offline
Old 08-06-2006 | 06:36 PM
JShoup's Avatar
Default Re: Twin I/O Power Steering units
Heres a quick drawing of what I have for hydraulic steering lines. Hopefully this makes sense.
Attached Thumbnails Twin I/O Power Steering units-resized-steering-dia.jpg
JShoup is offline
Old 08-07-2006 | 12:45 AM
2112's Avatar
I cant seem to turn this right side up. You may have to print it out. Hope it helps.
File Type: pdf
2112 is offline
Old 08-07-2006 | 02:48 AM
GOODT's Avatar
if using two pumps you need to install a check valve/metering block
GOODT is offline
Old 08-07-2006 | 09:14 AM
JShoup's Avatar
2112 - Thankyou, I had everything correct except I only need one resivor tank ??? I actually have the Keith Eckert Pumps so the plumbing into the pumps is a little different. Then I have check valves in line on the pressure out of the pumps before they Tee together and go into the steering valve. I see that I might also need a Hose Manifold Assembly or a metering block ???
GOODT Does the metering block reduce the pressure when running two pumps or is it like a check valve for flow direction control
Jud Shoup
(970)376-3704
JShoup is offline
Old 08-07-2006 | 09:28 AM
See the link in this post for the valve block you need.
http://www.offshoreonly.com/forums/s...ing+pump+valve
Gary
rdoactive is offline
cmizgo
7
07-18-2012 04:52 AM
Excalibur Dude
10
04-09-2007 06:11 PM
packinair
15
04-15-2003 09:59 AM
CHAOS REIGNS
5
12-11-2002 07:56 PM
Dolph
04-08-2002 11:16 AM
