gear ratios
Old 08-06-2006 | 08:06 PM
Default gear ratios
Are the lowers in xr, xz bravos the same?
Are the gear ratios 1.5 and 1.36 made in the lower or the upper? or is it a combnation of gear sets in the upper and lower that give you your ratio?
tomcei is offline
Old 08-06-2006 | 08:20 PM
rbtnt's Avatar
Default Re: gear ratios
Here is a link to a page of Mercury gear ratios that should answer your questions.
http://www.mtboats.com/outdrivegearratios.html
www.mtboats.com - Pages of boat related links
rbtnt is offline
Old 08-06-2006 | 09:44 PM
thanks, I didn't see an XR with a 1.36 I assume they exist??
Anyway my underlying question would be... Could some one mate a XZ upper 1.5 to a XR lower that was from a 1.36 and end up with some kind of hybrid or would it turn into a 1.36 or what? I know it would help if I knew what XR lowers were available.
I think I may have a miss matched gear set if that's possible.
I had an XZ 1.5 and put on an XR lower after I blew out the XZ lower and I have some wierd results.
tomcei is offline
Old 08-06-2006 | 10:06 PM
rbtnt's Avatar
XRs are available in 1.50, 1.35 and 1.26 depending on the lower gear ratio.
Your combination should end up at 1.34 by using the table in the link.
XZ 1.50 will have 32/27 gears in the top
XR 1.35 will have 15/17 gears in the lower
Match those in the table, you will have 1.34 ratio.
rbtnt is offline
Old 08-07-2006 | 07:19 AM
thanks, I miss read the chart
tomcei is offline
1 MAIDEN AMERICA
1
03-03-2007 10:44 AM
Panther
Prop Talk
8
04-12-2006 01:18 PM
bottomfeeder05
03-27-2005 12:41 PM
WETTE VETTE
2
02-23-2004 04:16 PM
kevin285
2
10-12-2003 10:06 AM
