Thermostat or not? >
Thermostat or not?
Thermostat or not?
Old 08-09-2006 | 09:00 AM
formula1's Avatar
Default Thermostat or not?
Thermostat or not?
I live in Florida, so cold weather isn't much of a problem
But, really, the question is: Do I really need to run with a thermostat? What are the pro's and con's?
formula1 is offline
Old 08-09-2006 | 09:27 AM
pkspx's Avatar
Default Re: Thermostat or not?
I hear the race boats run without.....
pkspx is offline
Old 08-09-2006 | 09:55 AM
If you are running a SuperCharger and the engine can cook the moisture out of the oil...your fine without one.
Back4More is offline
Old 08-09-2006 | 10:09 AM
Wobble's Avatar
SORE MEMBER
I prefer sea strainer and t-stat, however as stated above, if you are able to get about 140 water temp and sufficient oil temp of at least 180 then there is probably no reason to worry if it's a carb motor.
If it's injection motor then you should run the correct t-stat.
Wobble is offline
Old 08-09-2006 | 10:56 AM
formula1's Avatar
I should've posted that they are carb motors. It turns out that the port engine hasn't had a t-stat in years but the starboard one has. Now the starboard engine t-stat has gone bad, I was just wondering if it even matters putting it back in! The port engine (w/out t-stat) runs about 145 at idle and about 160 to 165 cruise + speeds. Of course the starboard engine was only a few degrees warmer when the t-stat was working.
I wonder if not having a t-stat would improve circulation somewhat?
formula1 is offline
Old 08-09-2006 | 12:26 PM
Rebel_Heart's Avatar
I run in warm water most of the time and my builder keeps telling me that I don't need a thermostat. My water temps are up there and my oil temps will get to 180-200.
Rebel_Heart is offline
Brandon
3
10-29-2007 12:01 PM
boatnt
2
02-13-2006 06:55 AM
boatman22
1
02-07-2006 08:49 AM
Perfectmix
9
05-06-2004 08:32 PM
BajaBuddy
0
03-27-2004 07:30 PM
