Raker II on Merc 2.5 EFI SS >
Old 08-19-2006 | 03:30 AM
Default Raker II on Merc 2.5 EFI SS
Hi!
I wonder if Bombardier has a propeller kit for Raker II props that fits Mercury standard propeller shafts?
I am currently testing props. Best props so far has been stock Mirage Plus 27 props (7/10 condition) spinning 87 mph at 6.800 rpms. Above this speed the boat need more trim, and the prop loose grip of the water.
I have also tried a stock Bravo One 28 pitch 4 blade set. Since its 4 blade props, they lift the transom somewhat, and the speed ended at 84 mph at 6.300 rpms. Above that the prop started to ventilate.
Tempest props would be nice, but they do not have tall enough pitch at LR. So I wonder how a Raker II set will perform, as the prop is high rake and carry the bow very well.
Propshaft is 1.25 inch below the bottom. I spin the props inward. Toe In is set neutral. I will check out with 1/8 inch toe in or to out. What do you reccommend?
Cruise is very efficient; 46 mph at 3.500 rpms, 53 mph at 4.000 rpms, 60 mph at 4.500 rpms, spinning the stock Mirage 27 Plus prop. 1;1,87 gears.
If the propshaft had been too high, the slip factor should have been higher?
What do you think?
Cheeeeers, Toffen G
Attached Thumbnails Raker II on Merc 2.5 EFI SS-bilder%2520juli%252006%2520071.jpg   Raker II on Merc 2.5 EFI SS-p25110706liten.jpg
Toffen is offline
Old 08-27-2006 | 03:56 PM
Default Re: Raker II on Merc 2.5 EFI SS
Hi!
Any ideas?
Cheeeeers, Toffen G
Toffen is offline
Old 08-28-2006 | 05:00 PM
throttleup's Avatar
Hello Toffen,
Unfortunately, the only way to change the hub on the Raker is to machine it out as you cannot re-hub an OMC to a Merc.
Julie
throttleup is offline
JnT
Prop Talk
1
06-23-2008 06:59 AM
dfealy
11
09-21-2007 04:07 AM
JnT
Prop Talk
1
10-16-2005 01:54 PM
BamBam
1
06-22-2003 07:11 PM
Shah Mat
5
10-14-2002 11:06 PM
