Difference between Bravo 1 and 1X gears >
Old 09-01-2006 | 10:50 AM
Default Difference between Bravo 1 and 1X gears
Can Bravo 1X upper gears be used in a Bravo 1 using all Bravo 1 components (other than the gears of course). Is there any benefit to doing it? Thanks in advance,
Rene
oldandtired is offline
Old 09-01-2006 | 11:51 AM
Default Re: Difference between Bravo 1 and 1X gears
The older bravo's ( I believe pre OM serial)
there is a upper rebuild kit available
that I believe has the X style gears in it.
There are different thickness bearing races
required...you have to check the case stamping
for proper conversion.
Mbam would know,I got a kit from him
back in june.
Maybe he'll chime in
JaayTeee is offline
Dock Holiday
Drives and Lower Units
4
06-23-2008 03:20 PM
Illusive
10
07-10-2007 07:51 AM
enticer
4
09-02-2003 10:16 AM
carreraboat
1
08-25-2003 09:12 PM
Shah Mat
3
02-05-2003 10:41 AM
