Winterization Question >
Old 10-16-2006 | 12:14 PM
Default Winterization Question
Can you winterize a motor without running it by just draining the block & Manifolds, pulling the thermostat and pouring Anti-freeze where the T-Stat goes until the block is full?
Donzi26ZX is offline
Old 10-16-2006 | 12:33 PM
SB
Default Re: Winterization Question
Some do - I don't. I made a super cheap tool to handle this much easier.After draining water, hook this up, fill with antifreeze and start it. I'd suggest 5-6 gallons.
See post #2:
http://www.speedwake.com/upload/show...ome+brew+tools
SB is online now
Old 10-16-2006 | 01:04 PM
Wally's Avatar
Were doomed!
you just have to be sure you get all the water out of the small pockets that may not drain and may not get anti-freeze.....like the oil/power steering cooler etc.....i just did this very same thing with my dads boat....he took the carb off to have it repaired...now it looks like it wont be back for a while so to be safe i winterized the boat as best i could....
-Wally
Wally is offline
Old 10-16-2006 | 01:30 PM
Problem is I need to send out my started that is shot and therefore can't start the motor but would like to get the motor winterized. I would rather run it but might not get the start back in time and just want to get the boat put away??? Does anyone do it this way?
Old 10-16-2006 | 02:18 PM
czy40p's Avatar
I prefer the starting method, but I have done both just make sure you find all the drains. I usually drop the hoses off the oil cooler, the recirculating pump, exhaust and the seawater pump. I did the family OMC for years and never even new about the antifreeze trick!
czy40p is offline
Old 10-16-2006 | 02:40 PM
Registered User
Drain the block/lines etc. Fill with antifreeze and you are good to go. If you are concerned, that you didn't get all the water out (which is probably true), use -100 and cut it by 1/3, and use that to fill the block. Unlike -50, the -100 is made to be mixed with water.
Use the 4 hoses from the Stat housing to fill. Large hose fills the block, 2 smaller hoses fill the exhaust manifolds, and the 4th hose fills the intake line. I always drain the lines at the impeller housing to make sure it doesn't have any water.
The only tool you need to do this is a 5/16" nut driver for the hose clamps. Can't be much easier
the duke is offline
baja bailey
07-20-2008 07:24 PM
Sea Ray 200
03-19-2007 07:57 AM
gripit
8
12-22-2004 02:26 PM
BajaBuddy
5
10-04-2003 10:55 AM
bcoffield
6
10-10-2002 03:48 PM
