28 bravo 1's tapping the limiters >
Old 11-05-2006 | 10:02 PM
berns29scarab's Avatar
Default 28 bravo 1's tapping the limiters
just picked up a 1999 353 formula fastec with twin 502 mpi's, extension boxes, and 28 b-1's and in 50 degree weather here in Jersey was tapping the limiters at 5150-5200rpms...suggestions
berns29scarab is offline
Old 11-06-2006 | 05:56 AM
throttleup's Avatar
Default Re: 28 bravo 1's tapping the limiters
Congrats on the new boat.
If they are just tapping the limiters you are just right. In the summer the rpm should be right where it needs to be.
What kind of numbers are you seeing?
throttleup is offline
Old 11-06-2006 | 07:31 AM
no gps in boat
Old 11-06-2006 | 07:47 AM
Sydwayz's Avatar
Forum Regulator
I'd agree. As soon as it gets humid come summer, and you put all of your gear, coolers, passengers, and fuel on the boat; you will be right where you need to be.
Sydwayz is offline
Old 11-06-2006 | 10:08 AM
Beak Boater's Avatar
Charter Member # 545
If you could get a handheld GPS it would help. If you are hitting the rev limiter and your slip is high, then maybe theirs a problem. But like already said your probably very close to where you need to be prop wise.
Beak Boater is offline
Old 11-06-2006 | 07:44 PM
Hot Boat's Avatar
Team Dysfunctional
Stop being a pu$$y with the new boat. Disconnect the rev limiter and hammer down like it was your old OB
If it aint broke .... I can break it....
Hot Boat is offline
Old 11-06-2006 | 09:01 PM
AIR TIME's Avatar
#1 wait till its warm up if it only drops 50 or100 rpm try labbed 30s. or#2 take the boat south for a long weekend and try it, borrow a pair of 30s or call bblades they have a testing props thing which, I will use in the spring for my boat. I think you pay the shipping for the props until you get it close then buy and lab to your needs .you may pick up more speed with labbed 30s at 4950 to 5000 then the stock 28s at5100 to 5200 if your hitting the limiters you might be running 5300 or 5400 without them which means the 30s then would be more like 5100. its a good deal with there borrow return and theres always the merc 5 blades to try with the boxes on there,
AIR TIME is offline
Old 11-07-2006 | 06:41 AM
i'm going to wait til the spring in my normal operating conditions thanks
Old 11-07-2006 | 07:30 PM
nordic95's Avatar
YEA WHAT HE SAID BERNIE
Hey I have two 30 bravo props and two 28 labbed by Merc props for you to try Bro,let me know when and where.Also a set or 29 mirage.
Nordic95
nordic95 is offline
Old 11-14-2006 | 07:51 PM
Nordic95
thanks bro i appreciate it.
737jetmech
Swap Shop
1
11-14-2008 06:03 PM
never enuff
Swap Shop
5
07-30-2008 12:41 PM
ROADHOG
Prop Talk
2
10-23-2006 07:57 AM
GK
Scarab
5
10-05-2006 01:12 PM
hp500efi
Fountain
0
07-28-2004 01:07 PM
