Info needed to make a trailer work with a Donzi 26zx >
Old 11-20-2006 | 12:28 PM
Registered User
Default Info needed to make a trailer work with a Donzi 26zx
I recently bought a 99 Donzi 26zx & it's on a "Float-on" trailer. The trailer is a very nice trailer, but it doesn't seem to be a correct set-up for the stepped hull of the Donzi. The forward step has been nicked by the bunk when it comes off, & that is floating it off. The way it is, I won't even try to drive it off or on. My question is, has anyone ever modified a straight bunk trailer to work with a stepped hull. Again, this is a very well built trailer, & I really would like to make it work, just looking for some ideas.
rangerrick63 is offline
Old 11-20-2006 | 04:29 PM
'05 Concept SF23
Default Re: Info needed to make a trailer work with a Donzi 26zx
Start the bunks at the transom with 1-2 inches extending beyond the transom. If the step is resting on the bunk, notch to fit the hull. You can power on but must float off a step hull, or the ramp has to be deep enough to clear the step.
f311fr1 is offline
Old 11-20-2006 | 06:20 PM
Registered User
Thanks for the input. Should the bunks extend past the first step? Right now, it stops right after the rear step, in other words, the forward step is not resting on the bunk, that is the one that hits the bunk.
mattd7
Prop Talk
1
06-02-2008 08:39 PM
GABLES
Donzi
14
11-02-2007 07:58 PM
J.B. Marshall
11
06-07-2006 06:50 PM
J.B. Marshall
04-09-2006 09:24 PM
dockrocker
06-02-2004 08:18 PM
