Anyone use oil additives ? >
Old 11-29-2006 | 08:01 AM
berns29scarab's Avatar
Default Anyone use oil additives ?
Been in the car busines for years and have tried almost all of the "MECHANICS IN A BOTTLE" and there are only 2 im a firm believer in. I use LUCAS additives in everything i own with an engine reguardless wether there brand new or used...bikes, cars, boats, lawnmowers etc...including 4 qts added to my f-250 powerstroke every other oil change. I use there injector cleaner, power steering and trans additives.
Have used Engine Restore on a few occasions with positive results in older high mileage cars and have seen it decrease smoking and in some cases increase compression, sometimes a lil and other alot and always a noticable power increase. Has anyone ever used Engine Restore in a marine application? Was contemplating trying a can in a pair of 502's with 280 hrs on them. Either way what are your thoughts ?
berns29scarab is offline
Old 11-29-2006 | 08:09 AM
Default Re: Anyone use oil additives ?
my buddies girlfriend had a Dodge Stealth with over 200k on it and around 100k he started using Engine Restore at every 5k oil change and the motor got a lil quiter, smoother with every oil change
Old 11-29-2006 | 08:33 AM
vandy021's Avatar
No. I don't recommend it. Especially with diesel engines. Mobil has Delvac 1 which will extend your drains and you will not have any makeup. Also great start up with cold weather, for trucks...
If your engine has been maintained throughout the life of the motor, you should be fine with a Lucas synthetic or another. I recommend gas additives, but none for lubricants.
My family has been in the oil business for over 50 years and we have seen more problems from extra additive packages than good in the long run. For the credentials. Please see website below.
www.genpet.com
vandy021 is offline
Old 11-29-2006 | 08:38 AM
offshoredrillin's Avatar
BG 44K in the tank every month is a sure winner
offshoredrillin is offline
Old 11-29-2006 | 09:04 AM
mcollinstn's Avatar
the additives I use are already in the oil.
Viscosity improvers, sludge solvents, EP additives, emulsion suspension additives, and water absorbers. They are all in there. That's what makes one brand and type different from another. Otherwise they all come from the same dead reptiles...
Additional additives are a "fixer". If your motors are maintained properly, there is no benefit from additional additives.
Usually, the mechanic in a bottle stuff has crap in it that frees up rings that are stuck w varnish. That speaks for the compression increase. Usually they have crap in them that causes the seals to balloon, which explains the temporary nature of the oil leaks that miraculously stop. Usually thy have long chain viscosity improvers that temporarily act to buffer normal engine noises by charading as a much higher viscosity stock for a few miles.
there is no magic in those bottles. Just chemistry.
If your motor is "right" then they are counterproductive to good practices.
Ever play with the Lucas gear oil additive display? Where it drags a big elastic film of lube across the gears? Ever notice how much HARDER it is to spin that one quickly? Nobody needs liquid rubber in a gearbox unless they are running it FAR beyond its design spec.
IMO at least.
mc
mcollinstn is offline
Old 11-29-2006 | 04:04 PM
jhiguy377's Avatar
Friction-Free - micronized lead and copper
jhiguy377 is offline
Old 11-29-2006 | 04:17 PM
Panther's Avatar
Frank's Marine Service
what about that ZDDP stuff?
Panther is offline
Old 11-29-2006 | 04:56 PM
wrinkleface's Avatar
I use Crown Royal. Oh Oh, that's 4 me!!
wrinkleface is offline
Old 11-29-2006 | 05:17 PM
stecz20's Avatar
stop asking dumb questions????
stecz20 is offline
Old 11-29-2006 | 05:42 PM
If my pockets were as deep as yours i wouldnt ask these kind of questions...i just run it til it blew then rebuild or replace...SO PUT A LID ON IT THERE SLICK !!
