Water mixed with the oil ? >
Old 12-10-2006 | 09:47 AM
rrentsch's Avatar
Registered User
Default Water mixed with the oil ?
I just purchased a 2000 34' PQ viper with HP500 efi's. the starboard engine has a coating on the oil filler tube that looks like white lithium grease I know that this has to be water mixing with the oil. My questions is how bad is this ? the motor ran just great on the flushing unit. looking into the valve cover thru the oil filler hole everything looked good,no white oil,no rusted springs, nothing. The oil was a shade lighter than the oil in the port engine. Anybody got any experiences with this problem ?
rrentsch is offline
Old 12-10-2006 | 12:42 PM
Crazyhorse's Avatar
Default Re: Water mixed with the oil ?
Yup. Possibly condensation. It's worth a closer examination though.
Crazyhorse is offline
Old 12-10-2006 | 05:37 PM
MOP
When you say the oil was a shade lighter do you mean "cleaner" this would make me a little suspect of a pre existing condition being covered up. Maybe I am a bit cynical but you get that way working around boats most of your life.
Phil
MOP is offline
Old 12-10-2006 | 05:49 PM
blue thunder's Avatar
If this engine has a pcv valve make sure it is working correctly. Also make sure the oil temp is getting above 212F.
BT
blue thunder is offline
Old 12-11-2006 | 06:43 PM
wrench01's Avatar
Probably simple condensation, normal.
CHECK the oil level, is it high?
Is it milky?
Oil level can vary when the boat's not floating, so if it's high by a quart....no worries.
If the answer to both are NO then you probably have no problems.
Change the oil and wipe off what you see and it might not be back.
wrench01 is offline
flatout
2
07-04-2007 05:18 PM
Steve Zuckerman
Nordic
17
10-20-2006 06:50 PM
Raypanic
Fountain
7
09-24-2006 08:00 PM
SPITFIRE
01-08-2004 09:23 PM
