sEA WATER PUMP DRIVEN FUEL PUMP
A quiestion for you guys about this, I have removed the fuel pump and installed a big electric Aeromotive pump that came with the pro charger. When I removed the mechanical fuel pump I noticed thet there was oilo in the area that the arm goes down into. Is this area fed oil from the motor or is it just a cavity that holds oil for the mechanical arm. I fired up the motor today and I guess there is a leak here because i noticed a good puddle of oil directly under the sea water pump....I did not put gasket sealer on itwhen installing the block off plate, so perhaps that is the problem, I am going to replace the gasket between the sea water pump and the block off plate and put sealer on it before torquing it down. Am I missing something here? Anyone enlighten me.
by the way this thing has some serious blower whine at idle, sounds good!
Bryan
Bryan
BillR
11
07-29-2022 06:31 AM
