Fuel Pump Advice Needed: >
Old 01-04-2007 | 04:14 AM
johnnyoffshore's Avatar
Unhappy Fuel Pump Advice Needed:
I need help finding a durable/long-lasting electric fuel pump. I have had several electric fuel pump failures in the past on my 850HP N/A single 1050 dominator carbureted motor and now I having built a 1000+ HP blower motor with 2-1050 dominators. There are no tight bends or kinks in the fuel line, everything is pretty straightforward. I use a high flow capacity fuel filter (that filters 60-100 microns) between the tank and pump. I am rewiring the fuel pump to a heavier 8-gauge wire and a shorter distance. My pump is located as low as I possibly can get it in the hull (below fuel line of tank) and with in 2’ of fuel cell (close as I could get it to tank). I am very worried about fuel pump failures. The past pumps I have used are: Holley Marine Black & a few different Mallory Marine pumps. What is the best marine grade electric fuel pump for a gasoline 1000+ HP carbureted blower motor with 2-1050 dominators, that uses -10 inlet/outlet fittings with no return line? I prefer no by-pass/return line, unless this is the reason for my pump failures, if so, is there a way around it? I was told that SX Performance electric fuel pump were the simplest and about the best pump?
johnnyoffshore is offline
Old 01-04-2007 | 08:30 AM
Elite Marine's Avatar
Default Re: Fuel Pump Advice Needed:
Your filter should be after the pump and more than likely you are experiencing the failures due to no bypass. Pumps are designed to run and flow, they should not be deadheaded.
What type of regulator are you using?
Everyone has a favorite pump - Aeromotive, Mallory, Weldon etc...
http://www.offshoreonly.com/forums/s...ight=fuel+pump
Elite Marine is offline
Old 01-04-2007 | 12:58 PM
Cat man do's Avatar
www.sx-performance.com absolutly the best period
Cat man do is offline
Old 01-04-2007 | 01:12 PM
I went with aeromotive pump and have a regulator/bypass thats dumps back into the fuel tank via a "T" fitting I put in at the filler hose for the tank. I run my pump at 35psi on my whipple 509mpi motor. Has been working flawless for me.
29scarab is offline
Old 01-04-2007 | 02:47 PM
RBT
Weldon
MAKE SURE it is well filtered. If you are having failures look to see how it is plumbed. Electric pumps are pushers not pullers, haveing to pull up hill kills them, haveing restriction kills them, hell even elbows kill them.
Big pickups, no anti-sypon valves, and oversize lines help a lot. Check out www.xrp.com for high flow fittings and hose...... this stuff makes Russel and Aeroquip look like crap....... and make sure your pump is at tank level.
RT
RBT is offline
Old 01-04-2007 | 04:04 PM
I Sell S-x Pumps And You Did Not Say What Size Your Fuel Pick Up Is. If This Is To Small You Will Cavatate The Pump , This Will Kill Any Pump. The Fuel Water Seperator Should Be In Front Of The Pump And A Filter After The Pump. You Should Also Return Fuel To The Tank To Keep The Fuel Cooler. We Have A Lot Of These In The Marine Market With Out Any Problems.
Jb-fse is offline
Old 01-04-2007 | 04:15 PM
I always run the filter before the pump via the instruction, every pump I bought said to do so, so the fuel is filtered before entering the pump. As far as regulator, I always bought the new ones that were recommended for the pump. I am sure if I run a return line it should resolve this issue and the bigger power 8-gauge wires should help too. Thanks for your help. I will buy a SX Performance pump.
Old 01-10-2007 | 07:35 AM
There are multiple things that can cause fuel pump failures.
- Feed line too small
- Vent line too small (pump will try to suck the tank inside out)
- Filter too restrictive (You should filter before, and after the pump)
- Bad plumbing etc.
If at all possible find a way to run a return style system this way the pump will not have to work nearly as hard!
RumRunner is offline
Old 01-10-2007 | 08:41 PM
monstaaa's Avatar
scrap the electric pump. keep it as a back up and go to a mechanical that actual was designed for the conditions we high per formance boaters put these engines thru.
and with out a doubt use a return style regulator.
install the reg. after the fuel log, this way if it faila you end up with too much fuel instead of a mess.
the pump is a vailbale from cv products. (it was designed and is used in nascar.)
the regulator is weldon's.
Attached Thumbnails Fuel Pump Advice Needed:-e1.jpg   Fuel Pump Advice Needed:-e2.jpg   Fuel Pump Advice Needed:-e7.jpg
monstaaa is offline
Old 01-10-2007 | 08:45 PM
monstaaa's Avatar
if you look close in the second picture you can see the cv pump. it works absolutely incredible without failure, and its design will support 1300 hp gas or alchohol.
also i would install a fuel cooler as to help moderate the temps of the warm fuel that is stored in your boat. helps to make more consitent h.p and helps to prevent detonation.
monstaaa is offline
