Fuel Pump Advice Needed: >
Old 01-14-2007 | 03:13 PM
monstaaa's Avatar
Default Re: Fuel Pump Advice Needed:
not off hand. if u call ramco performance ask for allan mckay and refer him to this unit. it flows 500 gph , is 5 micron, and plumbed with -12 orb. replacement element is 20 bucks
monstaaa is offline
Old 01-14-2007 | 03:42 PM
2112's Avatar
On their Website, I found the flowmax300 which flows 300gph and at 5 microns but no 500gph. Is it new?
2112 is offline
Old 01-14-2007 | 07:24 PM
monstaaa's Avatar
no, call and ask for allan.
monstaaa is offline
Old 01-14-2007 | 07:45 PM
bob
Charter Member #40
I have roughly 300 hours on the Hp version of the Aeromotives which are supposedly good for 1000hp? 5/8 out of tank to #12 line into Eickert filter/seperators, #12 to pump. #10 out to a fuel log feeding pair 950's, pressure reg keeps pressure at 6.5 and then returns to fuel tank with #8. Also run the Aeromotive controller which cuts down the voltage to pump below 1500 rpm or so. Has been trouble free.
bob is offline
Old 01-14-2007 | 08:24 PM
2112's Avatar
You run the same set up I do, Maybe I am OK.
BTW Eickert filter thread ID is .925" Gasket 3.25"
2112 is offline
Old 01-16-2007 | 09:35 AM
Originally Posted by 2112
Is there a high flow in line filter for before the pump in size
12AN availble? My aeromotive is size 10AN.
I am 12AN up the to pump and 10AN from the pump to the regulator. In a worse case scenario, would you anyone run no filter before the pump to keep flow high?
SX MAKES A HIGH FLOW WITH #12 INLET AND OUTLET #41003
Jb-fse is offline
Old 01-16-2007 | 01:42 PM
To Let You Know Sx Has A New High Flow Filter #41003 That Is A #12 Inlet And Outlet Flows Up To 180 Gph . This Was Develpoed Just For The Long Suction Lines In Marine Applications. This Filter Will Not Starve The Fuel Pump.
Jb-fse is offline
nordic95
19
10-01-2011 01:10 AM
alecsammy
0
09-21-2008 09:47 AM
EPKRC
05-01-2005 09:34 AM
f252tbird
5
08-25-2004 12:29 AM
David Haag
4
05-04-2004 08:32 PM
