Whats the largest boat you can pull with an f250? >
Old 02-02-2007 | 06:36 PM
Default Whats the largest boat you can pull with an f250?
In the market for a used 28-34 foot baja or cigarette,and I just want to know what is the largest you guys have pulled with an f250
West is offline
Old 02-02-2007 | 06:43 PM
tblrklakemo's Avatar
SeaRay Sundancer
Default Re: Whats the largest boat you can pull with an f250?
You will be fine with the right hitch and a diesel or v10
tblrklakemo is offline
Old 02-02-2007 | 07:01 PM
CMG's Avatar
CMG
I forget the numbers but I was within specs pulling 9,300lb boat and trailer with mine (gas)
Chris G.
CMG is offline
Old 02-02-2007 | 07:30 PM
I have a 6.0,Do you guys think I can a nice boat for under 90k?
West is offline
Old 02-02-2007 | 07:39 PM
lucky strike's Avatar
You can find a mid/late 90's Top Gun for $90k. They can be towed with an F250 too.
lucky strike is offline
Old 02-02-2007 | 07:46 PM
Registered User
Not safely or legally.
The 28 to 34' range will definitely be fine back there.
Chris Sunkin is offline
Old 02-02-2007 | 08:03 PM
32storm's Avatar
I would check with your Ford dealer. I was looking at a F250SD with the 5.4, and I was surprised at how low the tow capacity was vs the GVWR in the spec's in their brochure. Especially since I had already had a couple of friends tow my boat, it seemed like a good package. I ended up up buying a GMC with 6.0m that was rated for the load.
32storm is offline
Old 02-02-2007 | 08:10 PM
I had a F-250 4x4 crew cab last year & pulled my 43 Scarab with trips & my 42 GTX. The GTX was a little easier then the Scarab ( not a suprise ) but both where ok. You just had to watch for people stopping in front of you. It was a little short on brakes for the Scarab. By the way it had a v-10 & it wasn't has good has the 6.0 diesels I had in 05 & 04.
allfiredup is offline
Old 02-02-2007 | 08:24 PM
BBB725's Avatar
The F250 depends on the motor/ trans/rear end/wheel base
5.4 tows 9,600
V-10 tows 12,500
diesel tows 15,000
BBB725 is offline
Old 02-02-2007 | 09:37 PM
CMG's Avatar
CMG
oh ya, surge breaks suk.
Chris G.
CMG is offline
