Livorsi 4 5/8" DataTach/Prop Slip Multi Gauge
Livorsi 4 5/8" DataTach/Prop Slip Multi Gauge by Livorsi Marine
Info. & order link:
Livorsi's revolutionary DataTach™ Prop Slip™ Multi-Gauge is a digital gauge that lets you know if your getting the maximum performance out of your boat. This one gauge displays: Compass Heading, Single or Dual Tach readings, Propeller Slip, GPS speed and recall, and an optional Record and Document. The DataTach™ Prop Slip™ has a computer that receives GPS speed and RPM info and caluclates the slip of your boat's properller 5 times per second. A lower prop slip% = better performance.
DATATACH™ PROP SLIP™ MULTI-GAUGE
The Livorsi DataTach™ Prop Slip™ Multi-Gauge is offered exclusively at Livorsi Marine Inc
Large easy to read LCD digits can be seen in direct sunlight
Fits into a Monster GPS cutout
All readings with Recall
Optional Recording Module - see www.propslip.com for analysis results
Available in a Mega or Race rim in 13 brilliant colors to tie into any existing dash
Available for in-dash or portable version
Know your boats most effective drive height, trim angle and propeller size to gain more speed and increase fuel efficiency
Info. & order link:
I have been getting a lot of calls, emails and questions about this new multi-gauge so I thought I would take a few minutes to tell you a little more about the gauge.
The multi-gauge requires a 4 5/8" cut-out and is 5" overall...if you have an existing Monster Speedo it will work with the existing cut-out.
If you already have an existing Livorsi Monster GPS Speedo you DO NOT have to purchase another gps reciever...your existing one will work just fine.
It can be used in conjunction with your existing tach(s), or if you are in the process of upgrading your dash...we can configure your dash so that the multi-gauge takes the place of your existing speedo & tach(s).
Wiring the gauge is not anymore difficult than wiring a GPS Speedo or Tach.
Once you wire up the multi-gauge, you will have to tell it a little about your boat, i.e., gear ratio & prop pitch so that it can accurately calculate prop slip...check out the following link for more information.
Prop Slip, how it works
I hope this helps, but please let me know if you have anymore questions.
tpmarine.com
New Products and Member Discounts
5
04-03-2007 03:46 PM
teaguecustommarine
5
02-28-2007 05:23 PM
Livorsi Marine
0
02-16-2007 05:13 PM
