How do # of blades effect prop? >
Old 02-12-2007 | 03:40 PM
Default How do # of blades effect prop?
If I have a set of 3 blade 19x20s that work fairly well - what if any effect will 6-blade props have? Also, will they need to be much smaller in pitch or diameter to work?
This is for an arneson driven cruiser.
Swamplizard is offline
Old 02-12-2007 | 04:29 PM
WildWarrior's Avatar
Each added blade is one added pitch or a bit more, at least on our Cleavers that's how it works out.
WildWarrior is offline
Old 02-13-2007 | 03:56 PM
Default better
props running inthe water don't have shock when ventilated blade hits the water. six will run smoother and be easier to balance. I have five blade cleavers on my trimax's and would prefer six
milespm is offline
Old 02-14-2007 | 08:13 AM
throttleup's Avatar
Hey Swamp,
If your 3B props are runnig at the approriate RPM then you will need to decrease your pitch approx. 3 inches to maintain the RPM. Keep in mind this is with like diameter.
Julie
throttleup is offline
Z06
Prop Talk
6
01-17-2008 09:54 AM
Strip Poker 388
09-15-2004 06:53 AM
kozaman
2
03-11-2004 09:57 PM
Pure Energy
09-24-2003 06:47 AM
GO4BROKE
06-05-2003 06:21 PM
