Trim Tilt pump on merc outboard questions >
Old 03-13-2007 | 06:09 PM
Default Trim Tilt pump on merc outboard questions
I have an older set of 2.4 200 hp mercs they have the trim pumps mounted inside the boat. I was wondering are you able to use the new style pumps. They seem easier to find and are cheaper what is the difference?
oldschoolfan is offline
Old 03-13-2007 | 07:02 PM
Steve Zuckerman's Avatar
Yes,
Get the MerCruiser pumps, they are much faster than the OB units. Old drag racer trick.
Steve
Steve Zuckerman is offline
Old 03-13-2007 | 07:46 PM
Steve thanks for the info. here is the pic of the one I have.
Old 03-13-2007 | 07:48 PM
This is the one I want will this work. Any help would be great.
Old 03-13-2007 | 10:02 PM
OS,
I couldn't enlarge your second pic, but that looks like the MerCruiser unit with the plastic translucent reservoir. The motor is the same for both, but the I/O unit's valve body is plumbed to flow more volume, resulting in faster trim in an outboard application.
Steve
Old 03-14-2007 | 06:10 AM
copiercat's Avatar
the pumps will work in an outboard but the fittings are different on the line to pump, you can get the adapters from napa or another company in ny, if you need help with the part #'s pm me and i will get them for you
copiercat is offline
Old 03-14-2007 | 07:04 AM
hey thanks for the help I apreciate it.
josh
jlaudio29
7
02-12-2008 08:56 PM
boatdude2
4
03-14-2007 07:04 PM
ratman
01-26-2006 07:48 PM
blown formula
8
01-22-2003 09:42 PM
floatingphil
4
07-04-2002 11:20 PM
