Sucking out Gear Lube? >
Old 03-14-2007 | 11:09 AM
Bill 3's Avatar
Default Sucking out Gear Lube?
Anyone try sucking the lube out of a drive - from the bottom - with an oil change pump? I am trying to find a "better way" to change gear lube on boats that are kept on a lift. I have tried rigging it so the pan floats and is held by the skeg, but then a wave or something....
Any ideas or suggestions?
Bill 3 is offline
Old 03-14-2007 | 03:36 PM
Knot 4 Me's Avatar
Have a platform added to the back of your lift or pull it onto a trailer.
Knot 4 Me is offline
Old 03-14-2007 | 06:25 PM
ziemer's Avatar
Have you tried retro-fitting the threaded end (which screws into the drain on the back of the carrier) of a standard mercury pump that fits onto a quart bottle of lube to your oil change pump? Then you could use the oil change pump to drain and fill by just reversing the flow.
ziemer is offline
Old 03-14-2007 | 07:42 PM
Bill 3's Avatar
Well, that is exactly what I did. It took a while, but not like waiting for it to drain. The best part was not worrying about trying to keep a pan under the drive.
It was not on my personal boat, I was helping out a friend.
Bill 3 is offline
Old 03-14-2007 | 08:20 PM
As suggested, a strong stable service platform attached to the lift down deep (no risk of hitting it when pulling boat in) is the way to go. Once you install it, youll use it all the time.
Pismo10 is offline
Old 03-14-2007 | 08:33 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Tie a bucket underneath and let'r drain.
US1 Fountain is offline
jillybird
Drives and Lower Units
7
08-19-2008 10:45 AM
Griswald
3
12-08-2007 03:20 PM
ninetym
5
11-06-2007 05:43 PM
traviss
17
03-08-2004 05:06 AM
jafo272
8
11-22-2002 09:32 AM
