Go Back  Offshoreonly.com > Owners Forum > Powerplay
powerplay qusestion. >
Old 03-14-2007 | 07:11 PM
Dono's Avatar
Default powerplay qusestion.
Ok guys, I have a 1995 33 sport deck that i have someone looking at and upon inspection he noticed the floor under the u shaped seating (where the potty goes) is flexible. It does not seem wet but rater a light layup. We are just wondering if this is normal or is the floor rotten. When you knock on it, it doesn't have that dull thud you get when something is wet so im assuming it was just made flexible. Thanks
Dono is offline
Old 03-14-2007 | 07:48 PM
Mine is solid because that is where the crapper is mounted. The floor is probably rotted under the glass. I don't know if that is part of the liner or not, but pm Ed, he may know.
PPlay33 is offline
Old 03-14-2007 | 08:15 PM
Dono's Avatar
I never mounted the crapper i just set it in there when i take the girls out. It really does not feel rotten it just flexes when you push on it hard. kinda like when i walk on the deck it has that flex to it.
Dono is offline
Old 03-15-2007 | 06:47 AM
Indy's Avatar
Member #154
A moisture meter should make short work of that issue. I don't believe mine flexes, I seem to remember it was solid when I was putting the pot in.
Indy is offline
Old 03-15-2007 | 08:49 AM
Ed
Lightbulb Head Compartment Floor
It was rare, but its possible the glass/carpentry shop used a piece of 1/2" ply there, when it could have been a piece of 3/4". Or, it just was'nt screwed down to the center stringer for support before the compartment was glassed in. If your curiousity is killing you, cut a hole for a 4" or 6" pyhi(deck plate), off center, to clear the center stringer. You will have to countersink(recess) it, the thickness of your pyhi, so it remains flush with the floor surface. Reason being, there is so little height in that compartment to the bottom of the lid, and the toilet won't sit level as well. You can then screw and/or glass the floor panel to remove your flex concerns. Re-gelcoat the cutout to seal the hole before installing the new deckplate. Hope this helps.
Ed is offline
Old 03-15-2007 | 04:39 PM
Thanks DONO I've been trying to get an answer to this.....
SUNSATION 25 is offline
Old 03-15-2007 | 04:41 PM
Ed, I'd like to ask you some questions if you have the time....
E-mail [email protected]
Cell (586)883-4359
WS402
04-17-2008 03:22 PM
baja27
Powerplay
10
04-13-2007 09:26 PM
Semper Fi
02-06-2006 01:43 PM
baja27
09-22-2004 12:33 PM
nitro/max
6
12-29-2002 10:33 AM
