Hydraulic add on Steering >
Old 03-14-2007 | 09:45 PM
Default Hydraulic add on Steering
After installing the Brazil valve do you need to keep the control valve hooked up th the tiller arm or can I disconnect it. ? No instructions. I was told to disconnect the tiller arm to keep it from fighting with the add on cyl. The steering cable goes through the control valve. Not sure how it controls the proportioning vale to change directions.
Noise Pollution is offline
Old 03-15-2007 | 09:03 AM
obnoxus's Avatar
Charter Member #1171
I disconnect the tiller arm when I do installs.
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 03-15-2007 | 05:15 PM
blue thunder's Avatar
In a hydraulic system of any sort you need flow control or you get erratic cylinder operation. You need to either leave the tiller arm in place and regulate the airflow in and out the original steering cylinder, or you will need to install flow controls on one end of each external ram. Split the circuit so you have control in both directions.
BT
blue thunder is offline
djmadmatt
Classic Offshore
21
11-27-2008 01:38 PM
slik22
Wanted
6
05-04-2008 08:28 PM
point92mach
18
09-23-2007 09:33 PM
Cmoney
22
08-31-2004 06:51 PM
88Fount33
8
06-02-2004 09:19 AM
