Preventing Valvefloat >
Old 04-19-2007 | 07:48 PM
Default Preventing Valvefloat
I've been reading up alot on hyd roller cam profiles and valvefloat. I'm a little worried about my setup since I'm on the low end of recommened spring pressures.
355 SBC
AFR 190 heads
224/230 .537/.511 112LSA hyd roller
Morel vertical bar retrofit lifters
Smith Bros .083" 1 piece pushrods
Crane 1.6I and Lunati 1.52E widebody roller rockers
Manley Stainless I and Inconnel E valves 2.02, 1.60
PTV clearance I .246", E .229"
Isky #6105 dual w damper springs, 1.430" OD, 1.120" CB, 330lbs spring rate,
Seat 135lbs, Open 315lbs @ 1.260", 1.812" IH.
I'm breaking in the new drive so I have not had the motor WOT in the boat yet. On the dyno there was no float noticed but I feel under extended WOT runs on the water it might be different.
With the 23p it's gonna max out in the 5600-6000rpm range.
What do you guys think? Should I be allright or for saftey shim the spring pressure up?
Thanks for the help!
Ryan00TJ is offline
Haulin' 8.1
09-11-2008 07:36 PM
Michael1
04-07-2007 09:08 PM
justinVIP
3
11-18-2003 10:42 PM
C_Spray
04-08-2002 11:09 AM
