Low coolant in tank
Just uncovered the boat in anticipation of spring tune up. When I removed the cover from the drives I noticed a little bit of pink fluid. When I opened the hatch, port side coolant tank was very low. The engine was apparently properly winterized. Leak? Any idea? Should I be concerned. They are 496HO's. TIA.
Do a search in the General Q&A technical area for 496 Coolant Leak and you'll find some good info. Here are a couple of links:
http://www.offshoreonly.com/forums/s...6+coolant+leak
Hope that helps,
Chris
