Go Back  Offshoreonly.com > Owners Forum > Powerplay
Do Any 33PP Have..... >
Old 05-16-2007 | 09:19 AM
Default Do Any 33PP Have.....
Do any of you guys have documented boats which require document #'s inside the boat??
Also, do you have that plate thats required in the engine compartment?? Any pics where this stuff is mounted?
ActiveFun is offline
Old 05-16-2007 | 10:27 AM
Tony Montana's Avatar
The BAD Guy
http://www.offshoreonly.com/forums/s...d.php?t=157894
Tony Montana is offline
Old 05-16-2007 | 11:29 AM
JROMY's Avatar
Mine is documented. You do not need a plate in the engine compartment. You just need the numbers somewhere accessible in the hull, permanently affixed so if they are removed, the area will be disfigured. I used the vinyl letters inside one of the storage compartments in the cabin, and sealed them with clear epoxy.
JROMY is offline
Old 05-16-2007 | 11:32 AM
There is some other plate you need if your boat is over a certain size, not part of the documenting.
Old 05-16-2007 | 04:23 PM
JROMY's Avatar
You may be talking about the placard that states that dumping oil overboard is illegal and hazardous, etc., etc., etc. I actually need to find one of them as well.
JROMY is offline
Old 05-17-2007 | 09:51 AM
Yeah thats it. I was looking for pics of engine compartments that show both that plate, and the document numbers.
Old 05-17-2007 | 08:45 PM
Ed
Lightbulb Placard
Guys, those plastic placards are common & can be purchased from any West Marine, B.O.W.(Boat Owners Warehouse), Overtons, Lewis Marine, Land & Sea, etc., marine catalog or store.
Ed is offline
Old 05-22-2007 | 09:59 PM
Lickitysplit's Avatar
Registered User
Mine is documented and I agree with all of the comments above. JROMY has the best idea. I had
a sign shop router the Doc Numbers into a piece of starboard and the attached it to the bulkhead next to the toilet with 5200.
I suspect they'll need to destroy something to get it off but a good glass man can fix anything.
Mike
Lickitysplit is offline
Old 06-12-2007 | 08:21 PM
Active Streak: 30 Days
All true, but if the Coast Guard stops you and they (numbers) are not "permanant" be prepared for a big fine...over $1000.
Been there done that. Got my charges dropped but I had to provide photo's and a certifed letter.
Helmwurst is offline
Goin Nuts
Powerplay
4
08-18-2007 08:41 PM
ActiveFun
Powerplay
3
09-29-2006 09:21 PM
ActiveFun
Powerplay
8
09-07-2006 09:52 PM
Stormrider
08-02-2006 04:35 PM
