PLEASE! Need 350 sbc help asap. >
Old 05-16-2007 | 11:21 AM
Default PLEASE! Need 350 sbc help asap.
I need felpro head and intake gaskets part#s and rod and main bearing torque specs. Also the part # for a replacement piston is 735-850097 from mercruiser for $180!!! Can anyone cross this piston # for me? That is crazy money! This is my brothers boat and if we don't get it back together Him and his kids will be on my boat Memorial day! Puleeeze help me out!
P.S. the engine serial # is ok171493
kennyo is offline
Old 05-16-2007 | 07:43 PM
ken,
1. Look on the inside of the piston and see if there is a GM part number. Or take it to your local machine shop and they should be able to look at it and get you a piston. Probably less than $20 unless it is forged and even that should not be more than $60.
2. Same with the Fel Pro head gasket number, it is in the Fel Pro marine catalog. I have one at the shop but not at home, your machine shop should have one and be able to get you the gasket. These parts should be available to your machine shop in one day, they will have to press the piston off and back on for you anyway.
3. Rod torque ? Most are 45 lb ft but I would check the service manual to be sure. Mains are probably 75 ft lbs, but some of the newer models use a torque plus angle method so you really need the service manual to be sure.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
BillK is offline
Old 05-16-2007 | 08:18 PM
I think that the good fel pro headgasket number is 1010.
Nova 26 is offline
Old 05-16-2007 | 09:47 PM
Be sure that the new piston has the same weight as the original and use Victor gaskets, you will be glad you did. Any NAPA store can get them for you in the marine version, which is what all the OEMs' use
Old Ride is offline
Old 05-17-2007 | 03:16 AM
Big Block Billy's Avatar
Post
I have a s#!+ load of pistons and internal engine components. You can call me at 516 971 3175 if you cant find what you need. If I don't have it I can get it. Chances are I have it, BBB
Big Block Billy is offline
Old 05-17-2007 | 09:12 AM
Thanks guys. I talked him into a long block. We'll go through this one in the winter.
kennyo is offline
duunoit
3
06-01-2007 09:42 PM
Badtoon
2
04-21-2006 07:55 AM
Formula78
8
01-24-2004 06:58 PM
dma251
13
01-07-2004 11:47 AM
aero-offshore
07-12-2002 11:36 AM
