Bravo problem
Started the engine in neutral and revved it up. For some reason suddenly the forward gear kicked in. Now i can not get out of forward gear. It is stuck!
What to do??
What to do??
your chances are usaully slim when this happens. you will probably have to replace the entire upper gear set. oh and don't try and use one of your buddies one gear and not a complete set. these gears are a matched set. will you are in there you should probably re-seal the upper and get a new cone clutch which would just be obvious.
AHA! 1988 was the first year of the Bravo outdrive and there have been two major upgrades to the gear sets over the years. Send the drive to Doller or BAM and let them work their magic.
I will most likely go for a late year used drive. However, these are made for having an oil monitoring device in the engine compartment. How will that work with a 1988 transom assembly?
Where does the oil monitoring line come out of the drive?
Can I just skip that part?
