32 water puddling >
32 water puddling
32 water puddling
Old 05-28-2007 | 05:22 AM
Default 32 water puddling
Hopefully some other owners of the 32 can chime in. I believe this is a common problem with the design on the deck. My concern is when the boat is sitting in the water and if it rains, the water likes to collect between the first hatch and the bottom of the fairing. If your window is not completely latched or if your seals are bad, you get soaked. Has anyone come up with an idea or a fix for this problem. I was thinking about pulling down the headliner and installing a thru hull fitting and using that to act like a drain. I would notch out a groove so a drain hose would connect to the fitting and run the hose to the side of the boat and down the gunnel and tee it in to the bildge dumps. This way everything would be under the headlinder and out of view. Is this a crazy idea or do you think it would work?
Madkat is offline
Old 05-28-2007 | 06:32 PM
excursion's Avatar
I had a 32 and I always just used a big squigee , worked good to remove all the water. I just would not drill a hole in the top deck. Just keep the hatch closed GOOD!!!!
excursion is offline
Old 05-28-2007 | 07:51 PM
Good hatch seal and make sure its closed.
Griff is offline
Old 05-30-2007 | 04:37 AM
Thats one of the trades you make for the higher headroom when you sit!!!
32 Active Thunder is offline
Old 05-30-2007 | 04:58 PM
I am happy to say I have a solution....move to Florida..I dont think it has rained here since November.
THUNDER-STRUCK is offline
Old 05-30-2007 | 08:39 PM
chuckbeecher
From: Anywhere from the Laguna Madre to JAX and beyond
Seriously...we just ran REAL fast for a few minutes and it all blew away.
The poor bastard in the middle bolster got a quick shower but so what..it was refreshing!!!
chuckbeecher is offline
Old 06-01-2007 | 08:44 AM
Yes, I have done that a few times. The wife dosent think its funny, but I sure do.
Madkat is offline
Old 06-01-2007 | 08:46 AM
I ended up getting a squigee, it seems to work real well. Thanks
Madkat is offline
zimm17
8
07-10-2007 09:09 PM
MnHowardCat
7
05-29-2007 10:12 PM
waterbum
0
08-15-2005 10:36 AM
28Eliminator
11
06-22-2004 10:43 PM
Waterfoul
04-17-2003 08:01 PM
