Trailer ?
Old 05-29-2007 | 07:58 PM
masi242's Avatar
Default Trailer ?
I don`t have to trailer a lot and I changed all the bearings about 3 years ago when I put new surge brakes on. When I got home I touched the bearing buddies the front hub was hot to the touch the rears were much cooler. The brakes are on the front would that make that much difference?
Thanks for any help
masi242 is offline
Old 05-29-2007 | 08:08 PM
hubs on the brake axel will heat up after several stops.. drive it down the road and stop easy, jump out and check them.Then stop several times and check them again
tomcei is offline
Old 05-29-2007 | 08:19 PM
masi242's Avatar
Thanks, I was doing a lot of braking making our way to our house lots of small streets and stop signs.
masi242 is offline
Old 05-29-2007 | 08:39 PM
Yea, the axle with brakes will always run slightly warmer then the idler axles. Any play in the bearings?
happy hours is offline
Old 05-30-2007 | 08:43 PM
masi242's Avatar
no play in the bearings every thing is tight no leaks, It was the first time out this year so I forget a little.
masi242 is offline
PurpleStuff
2
06-21-2007 08:02 PM
Followmygut
2
05-13-2007 10:41 PM
Gene in NC
08-17-2006 09:56 PM
Poorsche
2
09-13-2005 07:30 AM
boot
11-22-2004 01:43 AM
