How to remove outdrive >
Old 06-05-2007 | 01:53 PM
mats's Avatar
Default How to remove outdrive
The outdrive is stuck in forward gear (Cone clutch frozen). How do I remove the drive considering that I need to disconnect the shift cable from the drive. That is hard to do with the drive in forward gear. Do I need to tear the upper down?
mats is offline
Old 06-05-2007 | 02:10 PM
ENFORCER24's Avatar
what kind of drive?
ENFORCER24 is offline
Old 06-05-2007 | 03:12 PM
If its a Bravo it should not make a difference. Mine was stuck in REVERSE and came off just like normal.
At least if you are stuck in forward you could put it on the trailer
1BIGJIM is offline
Old 06-05-2007 | 03:33 PM
ENFORCER24's Avatar
alpha wouldnt either , i'm pretty sure
Old 06-05-2007 | 04:17 PM
mats's Avatar
It is a Bravo. The problem is that when it is stuck in forward, the end of the shift cable is buried deep in the hole on the drive and the jaws that clutches the shift cable end can not open. How do I release the jaws mechanism given that the cone clutch is frozen?
mats is offline
Old 06-05-2007 | 04:33 PM
Vinny P's Avatar
I hate the winter!!
You will have to take off the back cover and release part # 14 from 13 in the attached picture.
http://www.mercruiserparts.com/Show_...ift+Components
Vinny P is offline
Old 06-05-2007 | 10:53 PM
Mr Gadgets's Avatar
Charter Member #601
Remove the bolt from the linkage, like Vinny says and it will rotate and let you remove it. It is an allen head bolt and will be covered with grease.. Or remove the upper one in the shift fork. Either will let the shift rod swivel and allow you to remove that drive. When you get it off.. just ship it to me and I can fix it.. Just kidding, that would be a trip!!
Time for me to get to bed.. must be in FL by noon tomorrow..
Mr Gadgets is offline
Old 06-06-2007 | 01:57 AM
mats's Avatar
Thanks guys. This board is increadible!
mats
mats is offline
Yellow_ICC_OK
17
10-21-2008 02:48 AM
niceguy
03-30-2008 09:34 PM
jdinvt
09-04-2007 07:13 AM
Von Bongo
Cigarette
4
06-23-2004 02:17 PM
rich allen
8
05-21-2004 07:21 AM
