Buzzer Alarm questions
My buzzers will sound off for a long time with out stopping, fluids all check out fine and temp as well, if I turn off the engines after running for a few minutes when I turn them back on they usually stop. Any ideas? This is on a 1991 Formula standard Merc / Bravo setup.
The buzzer alarm operates by a sensor grounding for low temp, low oil pressure, low fluids, etc.
You'll need to find out which sensor is grounding to find the problem.
At startup the low oil pressure sensor will usually be the ground. Is your oil pressure at idle ok?
Whay do they stop after turning them off and on several times?
