500efi"s time and rebuild >
Old 06-08-2007 | 01:26 PM
Default 500efi"s time and rebuild
i'm looking at a 01 36' baja with 500efi's and was talking to a salesman that said you have to rebuild after 400 hours anyone out there can help me would be appreciated. thanks.
KDAWG is offline
Old 06-08-2007 | 02:57 PM
Smitty's Avatar
I don't think you HAVE TO do a rebuild, but definitely do a leakdown test and that will tell you more. Then you may only need to have the heads refreshed and then rock and roll.
Smitty is offline
Old 06-08-2007 | 03:01 PM
at how many hours would you recommend the leak down test? and what is the cost of freshing up the engines?
KDAWG is offline
Old 06-08-2007 | 04:27 PM
carney's Avatar
do a leak down , if it passes change the valve springs or do a complete job and run it, Those motors should go 800hrs if taken care of. cost will vary , have someone with a good track record help.
carney is offline
Old 06-09-2007 | 08:09 AM
Smitty's Avatar
Do a leakdown test if over 200 hrs.
Smitty is offline
Old 06-09-2007 | 02:43 PM
Merc Racing recommends spring replacement and new head gaskets with a leak down test @ 250 hrs. If no other problems exist then around 500 hrs you should count on a rebuild. Rebuilding stuff that ain't broke is much easier than stuff that is.
gofastlvr is offline
Old 06-10-2007 | 12:39 AM
The 250 hour thing is on non efi engines. They recomend 400 hours to do the valve cover pull and check the heads. They had problems with pre efi engines.
satisfied1 is offline
Old 06-11-2007 | 08:32 AM
how much are you looking at to do everything at the 400 hours? i really need your help to determine if i'm buying this boat or not. please help asap.kdawg p.s boat had all leak down test and all replaced parts 20 hours ago. per owner
KDAWG is offline
LostinBoston
19
11-30-2007 04:14 PM
28Eliminator
24
05-25-2007 09:51 AM
Thunder Struck
12
08-30-2006 10:29 AM
miamioffshore
01-25-2006 01:50 PM
Shooter
1
08-15-2004 05:47 PM
