496ho seawater pump failure >
Old 06-18-2007 | 11:58 AM
Default 496ho seawater pump failure
I was told my serpentine belt fell off of my 496ho because the bearing in the sea pump were bad enough to allow the sheave to travel in and out and kick the belt off.
Has anyone run into this?
twanger is offline
Old 06-18-2007 | 12:16 PM
Reckless32's Avatar
Rough Seas Lie Ahead
Any sounds/noises form the pump prior to, or any vibrations in the pulley when at idle? Typically with bearings on most any pump/pulley system will give you a little warning, though subtle.
Reckless32 is offline
Old 06-18-2007 | 01:36 PM
no noises over the straight exhaust. So it could have been making noises, but I didn't hear it. I will know more when I get the old pump back.
twanger is offline
Old 06-18-2007 | 03:00 PM
tblrklakemo's Avatar
SeaRay Sundancer
YES!...similar. I had an 01' baja with a 496 MAG prior to my fountain. The weld that holds the pulley wheel on to the sea water pump shaft failed and the pulley wheel would move on and off of the shaft....not to mention it wouldnt spin the pump. Subsiqently the engine belt wouldnt stay on.
tblrklakemo is offline
BillR
27
08-10-2008 11:31 PM
SED70
8
03-31-2008 03:15 PM
outlawinil
2
06-24-2007 10:28 AM
BillR
4
02-06-2007 03:23 PM
BeakBoater35
4
08-29-2005 08:33 AM
