04 292 problem help! >
Old 06-18-2007 | 06:03 PM
Default 04 292 problem help!
I have an 04 292 with 6.2's that's causing me some problems. When the water's rough, the warning alarm will beep twice then the starboard engine will die on me. It only does this in rough water and it never does it when I have a mechanic on board. Any ideas? Thanks-Nick
NICKM is offline
Old 06-18-2007 | 08:32 PM
rhsj2006's Avatar
Can you provide more data? Are you running flat out, or idling? The more info you post the better your chances of getting some helpful suggestions...
rhsj2006 is offline
Old 06-18-2007 | 10:36 PM
Expensive Date's Avatar
Sea water pump???
Expensive Date is offline
Old 06-19-2007 | 12:39 PM
When it happened the first time, we thought it might be some kind of electrical problem related to the TV that fell off because when we hooked the computer up to it it said there was an electrical surge of some kind. When I was in Havasu the fuel pump on the starboard side would not turn off. This is no longer happening. Don't really have much more info than this. We're going to hook the computer up this weekend while running the boat on the water. Maybe I'll have more info then. Thanks-Nick
NICKM is offline
Old 06-19-2007 | 12:41 PM
A couple more things: This problem only occurs in rough water. The engine will die around 4500 to 5100 rpms. I'll start it back up and it will be fine. No, fuel, overheating, gear oil problems at all. Thanks-Nick
NICKM is offline
Old 06-19-2007 | 02:41 PM
Live Wire II's Avatar
Look for a loose wire behind the ignition, I had a loose one, and when I'd hit some rough water or a large wake, it would quit, but it would start right back up.
Live Wire II is offline
Old 06-19-2007 | 03:06 PM
tblrklakemo's Avatar
SeaRay Sundancer
We had a fuse wiggle out that would do that sometimes. Most likely that or a loose wire. Only about 4 miles of wire to check in each boat.
tblrklakemo is offline
Old 06-20-2007 | 04:14 PM
I'll check for loose wires. Hopefully it's the first 10th mile of wiring! -Nick
NICKM is offline
Splitdecision271
07-05-2008 12:13 PM
Treads
12-14-2007 10:55 AM
zoomer
01-28-2005 08:55 AM
timucin
25
12-05-2003 12:00 AM
Mark D
08-17-2003 10:01 AM
