TRS Max Trim? >
TRS Max Trim?
TRS Max Trim?
Old 06-26-2007 | 07:37 PM
Default TRS Max Trim?
Whats the specs for them max "safe" trim level? I have mechanical indicators, that range from 0-6. When I raise the drives to #6 on the indicators, I still have about 3 inches of outdrive inside the guides on the gimbles. It seems like there is more to go. I usually trim up to about 4 or 5, but never felt the props cavitate ever. Thanks, MT
MILD THUNDER is offline
Old 06-26-2007 | 09:16 PM
tblrklakemo's Avatar
SeaRay Sundancer
Too high is when the boat stops getting faster
tblrklakemo is offline
Old 06-27-2007 | 05:49 PM
No one has the measurement from the trim rams?
Old 06-28-2007 | 09:32 AM
Wally's Avatar
Were doomed!
you cant go by measurements cause evey boat is different....youll just have to go out and play with the settings till its starts to blow out on ya.......on my old scarab i could trim the TRS drives up quite a far way...had a decient rooster going right before it let loose...
-Wally
Wally is offline
Old 06-28-2007 | 03:29 PM
98itrwhite's Avatar
isnt that bad for u-joints?
98itrwhite is offline
Old 06-28-2007 | 03:48 PM
Wally's Avatar
Were doomed!
if you get it way up there yeah....i once did it and stopped the boat to see how far up the drives actually were.....it didnt look like it was anywhere near binding the joints....i had the boat for 3yrs and never a problem with the u-joints.....blew the lower gears on one drive the 2nd yr but i suspect that was due to the water intrusion we found later
-Wally
Wally is offline
spk1
07-11-2006 08:33 AM
Dregsz
3
07-10-2005 07:36 PM
Poorsche
6
10-20-2004 11:31 AM
Bad to the bone
4
12-26-2002 07:52 PM
Steamin Rice
15
08-14-2002 05:32 PM
