rust!!!!!!!
This is the best stuff I have ever seen. This stuff actually smokes when you open the bottle.
http://www.westmarine.com/webapp/wcs...33&classNum=34
Would something like CLR work?
I too have a bad rust stain on the non-skid deck.
Years ago I used a commercial toilet cleaner called "Gun Smoke" it would produce smoke (acid vapors) as it was applied. Sure was strong but it did the job.
I just removed some rust from my gelcoat yesterday. theWorks toilet bowl cleaner. It works real fast. Wear rubber gloves, squirt it on and use either a scotch brite pad or the sponges side. Rinse well with water.
It did take off the rust stains.
I tried the CLR toilet boawl cleaner and it did not work.
