496 mag idle problem >
Old 06-29-2007 | 04:51 PM
Default 496 mag idle problem
I have a 496 mag that will die sporadically, only at low throttle or idle. The fuel pumps will run, as if they are trying to prime the engine at initial start up but they will not stop running and motor will not start. Turn off the key and same problem, pumps just run and run.
Now it gets more confusing, I can turn off the battery to the engine and turn it back on and everything works and runs fine (for a while then it will die again).
I live in semi-remote Alaska and the only service guy here cannot figure it out. It gives no error codes on his laptop.
Any ideas?? There is no other service department where I live any help would be appreciated.
ak_boater is offline
Old 06-29-2007 | 05:06 PM
Trippin's Avatar
It sounds initially like an ECM failure (however unlikely) but without the ability to survey the situation myself no-one can be sure. Your going to have a tough time figuring that one out without the benefit of a qualified service person.
Start first with an IAC reset and make sure all battery conductors, and secondary connections, grounds and main power conductors are clean corrosion free and secure. You'd be amazed what kind of trouble poor grounds can cause.
Trippin is offline
Old 06-29-2007 | 06:13 PM
Wow, thanks for the quick response. How does one reset the IAC. (Idle Air Control I take it?)
Is this something I can do?
Old 06-29-2007 | 08:18 PM
Trippin's Avatar
You cannot reset the IAC (yes, Idle Air Control) yourself, a qualified service technician must do that, or at least someone with access to and knowledge of the Mercury diagnostic equipment, IE: the Laptop or the Scan tool. Best of luck I'm sorry I could not be of more assistance.
Trippin is offline
Old 06-30-2007 | 07:48 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
You should also double check the throttle body's butterfly setting.. Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 06-30-2007 | 10:38 PM
monstaaa's Avatar
there is also a small passage in the throttle body above the throttle plate which has a small square piece of foam type element in it. this the iac passage. at times it as well as the iac can build up a residue known as throttle body coaxing. essentially this means to clean the entire throttle body, passages, annd throttle blade .
monstaaa is offline
Old 07-03-2007 | 12:51 PM
Thanks for all the input. I am trying the ideas you guys have.
Is there a way to test the ECM? I am being told there is not. Awfully expensive for a new one if that is not the problem.
Harper220
27
07-22-2014 04:42 PM
cgharreell
12
05-09-2013 12:46 AM
stuball
1
08-06-2006 10:49 AM
BajaRunner
13
10-26-2004 11:04 AM
timucin
4
04-23-2004 05:04 PM
