Refresher course on tabs
Old 06-30-2007 | 09:28 PM
BL6
Default Refresher course on tabs
Guys, maybe the memories slipping, but I've got a new boat & have confused myself on tabs. 35' twins, step hull.
Say I'm running into waves, & boat is leaning; port high starboard low. Do I want to drag my port tab, or does that make it worse? Or, would you adjust starboard tab?
Thanks for the help.
BL6 is offline
Old 06-30-2007 | 09:43 PM
Ron P's Avatar
Enjoy the show
Think of tabs like airplane ailerons. Same concept. If you want to raise the port side, lower the port tab.
Tucks the drives first, if you need more use the tabs. Trim in during a head sea and trim neutral to out for a following sea.
Be Safe. Always move trim in small increments and wait for the effect to take hold of the hull.
Most importantly. If you have trim indicators, put a straight edge on the bottom of the boat and mark the indicator with a dot of nail polish where everything is level with the bottom. This way the indicators will have some meaning.
Ron P is offline
Old 06-30-2007 | 09:57 PM
Good Info Thanks
SpeedyWho is offline
Old 07-01-2007 | 05:59 AM
BL6
Ron - nice & clear, for some reason I was thinking the reverse on tabs effect. Also need to wait for effect to respond before more fine tuning. Looking forward to getting on water today!
BL6 is offline
Old 07-01-2007 | 07:47 AM
Donzilla's Avatar
BL6 when you say waves how big 2 to 3 or less? My 353 needs positve trim in any condition bigger water less trim but always + and I always use a the tabs to keep it straight one or the other.The 353 likes alot of trim or it will bow steer.Ron is right only bump the switch on the tabs when running hard cause to much will scare the chit out of you It is a great handling boat. goodluck with it.
JIm
Donzilla is offline
Old 07-01-2007 | 10:03 AM
el indio's Avatar
after reading this i know why the insurance rates are what they are...is it a new boat to you or new boat....if new tell which dealer is not prepping his customer..twin-step will ro
ll on command..........
el indio is offline
Old 07-01-2007 | 10:34 AM
omerta one's Avatar
Watch Reggie's segement on tabs in APBTV Episode 2:
mms://media.offshoreonly.com/OSOTV/Wmapbtv-episode2.wmv
omerta one is offline
Old 07-13-2007 | 09:49 AM
Registered User
I've gotten a bit more comfortable with my ZX, but I do have a question about tabs. I haven't really used them for anything other than leveling the boat; & I've been conserative with the amount of trim (it's the stepped hull thing ). I usually trim it to the point that I can feel the boat get a bit loose in the back, then I bump it back down a bit, but it seems as if that is where the boat wants to run. I just don't like the feeling, or perhaps I just haven't gotten used to the feel. So my question is....When I get to that point with the trim, would it benefit to drop the tabs a bit, or would that make things worse? This is only going straight, not while turning...that could be a bad thing .
rangerrick63 is offline
GEORGE YURICK
Superboat
10
04-13-2007 12:23 PM
camptappakeg69
04-13-2006 11:24 PM
boatme
10-03-2005 10:48 AM
