Coolant leak? >
Coolant leak?
Coolant leak?
Old 07-03-2007 | 09:38 AM
AKA NoMoBoatin
Default Coolant leak?
I just had my 525efi/whipple charged engine that was just rebuilt.It has 7 hrs. on it and its leaking coolant out from the coolant tank cap,is what it looks like.I have changed caps from 1 engine to the other and its still leaking when running.Installed cometic gasket on it and have been told it's not a leaking head gasket.The temp. is fine.Have checked all hose clamps and can't find anything else.Should I put some stop leak in it and or a leak down test.Thanks
docmanrich37 is offline
Old 07-03-2007 | 09:55 AM
OldSchool's Avatar
At what point do you forget to put in the plug and go for a ride????????????????????
OldSchool is offline
Old 07-03-2007 | 10:03 AM
AKA NoMoBoatin
Can't to busy workin on it all the time.It's been running great just trying to get the little things done before the p.r. next weekend.
Old 07-03-2007 | 10:11 AM
OldSchool's Avatar
Good to hear that it's finally running. That had to be a huge test of your patience!
Be safe at the poker run!
Old 07-03-2007 | 11:01 AM
Reckless32's Avatar
Rough Seas Lie Ahead
Is it the heat exchanger? or reservoir? Leaking externally, or internally?
Reckless32 is offline
Old 07-05-2007 | 07:45 AM
AKA NoMoBoatin
Its leaking around the outside of the cap around the coolant tank.To much pressure maybe.Plus I hear a whistling sound when I shut the engines off,like a leaky tires does.
jmeng
11
05-11-2008 07:05 PM
fatdaddy
Baja
2
04-25-2007 09:30 PM
betitbig
7
08-12-2005 07:45 PM
mg503
7
02-05-2005 01:05 PM
Mr. Gov'nt
4
10-01-2004 10:02 PM
