223LS questions
Question on dashboard for formula 223LS how do you tighten it? are the screws underneat the upholstery?
Second how hard is it to remove the winshield so I can reseal it? Thanks guys
I realize that this is an old post, but did you ever figure out the windshield? I have a 223SS with a loose windshield where the 2 halves meet. How the heck is it held together? Can it be tightened?
It's just screwed to the deck. Peel out the black plastic trim at the base of the windshield, there you'll see the screws. Then unscrew the grab handles inside and it'll lift right off. I don't know how the sections come apart but I'm sure that will become evident once the whole thing is off the deck. Obviously, this is not a one-man job.
Are you talking about the panels on the dash or the actual dark colored top section of the dash? If it's the top section you're talking about, you'll need to remove the windshield to get at the dash screws.
