Nav lights too dimm >
Nav lights too dimm
Nav lights too dimm
Old 07-15-2007 | 04:07 PM
Default Nav lights too dimm
Last season I lost the rubber boot that covers the receptacle for the stern light on out fastec. Now I have noticed that the stern light does not light up as bright as it should. And now it seems that the bow nav light is not as bright as it should be, especially the green side. Is this probably due to corrosion building up in the stern receptacle?? Any one else have this occur?
cstobe is offline
Old 07-15-2007 | 07:29 PM
Audiofn's Avatar
Charter Member #232
Check your grounds?
Put your best foot forward!
Audiofn is offline
Old 07-16-2007 | 07:37 AM
No, not yet. I need to relace the stern light base any way because of the missing boot. If that doesn't cure the problem then the grounds are going to be next. If my memory serves me well there is a grounding block just above the port side battery in the engine compartment. I should probably be checking for lose stuff as the water keeps getting rougher on our lake. Thank you for the input
cstobe is offline
Old 07-16-2007 | 01:16 PM
Audiofn's Avatar
Charter Member #232
You may be able to call Formula and get wire diagrams from them.
Jon
Audiofn is offline
Old 07-16-2007 | 06:38 PM
trips2win's Avatar
check the voltage on your battery
's might be time for new one's
trips2win is offline
Old 07-19-2007 | 06:26 AM
offthefront's Avatar
Sounds Like Corrosion has built up in the stern light and is shorted (slightly) from positive to gnd ... that will pull the voltage down ... any lights on the same circuit will dim ..clean or replace the recepticle ...m
offthefront is offline
Old 07-19-2007 | 06:34 AM
Trick Marine has an Automatic LED Stern Light ..I have one and is nice ..switch on the Lights and it motors up ...m
Old 07-19-2007 | 06:37 PM
Thank you for all the input. I have a new stern light base from my local formula dealer & I'm heading down tonight to install it . Hopefully this will be the cure. At least I enjoy working on the boat!
cstobe is offline
Old 07-20-2007 | 12:01 PM
tblrklakemo's Avatar
SeaRay Sundancer
Did it work?
tblrklakemo is offline
Old 07-23-2007 | 09:43 PM
Well I had no luck in replacing both the stern light base & the bow light. The grounds behind the gauge panel & at the rocker switch were all tight. I had already tried a different stern light pole. It seems that the bow light is getting too much voltage & the stern is not getting enough. So I'm going to leave it up to a marine mechanic to figure it out.
cstobe is offline
KEPP
New Products and Member Discounts
0
03-11-2008 09:27 AM
eliminatethis
Boating Safety
8
11-27-2007 07:51 PM
pkspx
Powerquest
5
08-24-2006 12:18 PM
GO4BROKE
Sonic
2
08-22-2006 08:52 PM
kook
6
01-31-2002 08:41 PM
