Speed Question 260SS
Here's the rub: I have a 2001 260SS with the VP 7.2GI DP. I like the boat - but sometimes wish it had more speed on tap without having to run WFO. I can cruise all day at 30 to 35 MPH +- Top end is 45-47 under good conditions.
Anyone have any experience with this model and a HO motor such as the 496HO? My alternative is to go to the Fastech, but I would have to give up some of the room.
Fire away with the opinions.
Here you go... MAG results from BoatingLife Magazine
Formula 260 BR
By Robert Stephens (more by this author)
It figured that the first boat on which we'd find Mercury's new Digital Throttle Shift (DTS) would be a Formula. The "fly-by-wire" system works digitally and makes for the smoothest shift and throttle control we've ever experienced, which is why we say it's fitting for a Formula. Everything about the 260 BR, inside and out, challenges the standards of perfection.
Simply flipping up the seat bolster at the helm stands out because it becomes a flush leaning cradle, like the kind we find on performance boats. On a day when we were avoiding the middle of our test lake on most boats, we stood through the rough stuff on the 260 and noted how solidly the boat held its ground, even in hard turns. It sounds like hyperbole, but the ride was so silky that 53 mph seemed like 30.
Lift is key to milking speed from a big hull. But we think boaters are more impressed with sturdy cruising than with flat-out quicks. And that?s harder to accomplish in a boat than in any other type of vehicle.
A close inspection reveals why the 260 stands so firm. If the builder is so particular as to plumb cup holders to the bilge or to use acrylic hatches to prevent gouges or to finish the bilge with gelcoat or to include porcelain in the head (like home!) ... then you know everything has to be first-rate.
Quality comes from fit and finish, which are costly for Formula to accomplish. One example on the 260: the wet bar (with two Corian tops that open in perfect synch on gas struts) is a separate unit from the deck. So are the fiberglass bases under the double-wide helm seat and the engine compartment. Because they are not molded in, the units won't flex with the deck, which over time would skew the seat cushions and hatches into a cockeyed fit.
Our test boat came with Formula's latest feature -- a wakeboard tower so brawny it could be mistaken for a stainless-steel radar arch. It's double-railed and allows a Bimini top to fit within the frame. Like everything else on the 260, it?s a premium component and not an afterthought -- for boaters willing to pay for top-line equipment throughout.
Stats
Length Overall: 26' Beam: 8'6" Dry Weight: 5,250 lb. Seating/Weight Capacity: n/a Fuel Capacity: 92 gal. Max HP: 425 MSRP (test boat): $99,845
Test Drive
Test Engine: MerCruiser 496 Mag Test Prop: 26-cup, stainless steel Test Load: People (360 lb); Fuel (70 gal.) Top Speed: 53.1 MPH @ 4,600 RPM Time to Plane: 5.6 sec. Time to 30 MPH: 9.0 sec. Min. Plane Speed: 21.5 MPH @ 2,400 RPM
Formula 260 BR
Stats
Test Drive
Thanks Boomer. I appreciate you posting the test report. Does not appear that the extra ponies deliver a whole lot more. Enjoy your 260 - I have had mine for 5 years - still looks brand new.
Have a great weekend!
