Need help with cam choice >
Old 07-23-2007 | 10:52 PM
scooby94's Avatar
Default Need help with 454 cam choice
I have a 96' 454 Mag EFI/mp motor. Just had the heads redone and port and polished. Dropped a #1 intake valve. Possible going to change the stock exhaust. I need to know what cam to go with, size, with out having to re-map the ECM. Trying to get some added power without having to change major componets.
scooby94 is offline
Old 07-24-2007 | 09:01 PM
scooby94's Avatar
Does anybody have any advice?
scooby94 is offline
Old 07-25-2007 | 09:47 PM
KAAMA's Avatar
Call "RMbuilder" aka Bob Madara of Marine Kinetics in New York. He is very good with marine cam apps and has done mulitple cam apps for guys here on OSO, etc, including mine. 585-654-8583
KAAMA is offline
Old 07-26-2007 | 07:54 AM
oreo11zeus's Avatar
Default 139021 Crane Rocks
The best mid-range cam used in the 502 540 and I use it in my 572's - LOVE THIS CAM!!!!
Good mid range torque and HP, fair idle, performance usage, mild bracket racing, good w/manifold nitrous system, auto trans w/3000+ converter, marine applications: for 454-502+ cu.in. modified engines in performance applications with aftermarket dry pipe exhaust systems. 3400-3800 cruise RPM, 10.0 to 11.5 compression ratio advised. Good w/Roots supercharger, 15 lbs. maximum boost w/8.0 maximum compression ratio advised.
http://www.cranecams.com/index.php?s...21&lvl=2&prt=5
oreo11zeus is offline
inxs01
10
01-28-2008 11:46 PM
brians fever
8
01-03-2008 11:46 AM
f_inscreenname
14
12-25-2006 02:07 PM
OldEliminator
8
05-26-2005 07:57 PM
dyno
15
09-02-2004 02:19 PM
