Big cubic inches or supercharger? >
Old 07-24-2007 | 06:31 PM
Default Big cubic inches or supercharger?
What would you rather have?
A large bore motor (say 600+c.i.) or a 502 (ish) supercharged motor making equal horsepower?
whats the pros cons of each?
waterboy222 is offline
Old 07-24-2007 | 06:34 PM
JIMKID Motorsports's Avatar
a blower makes a little motor think its bigger but is hard on parts there really is no substitute for the all mighty cubic inches
JIMKID Motorsports is offline
Old 07-24-2007 | 06:45 PM
36spectre's Avatar
Registered User
uh.......both.......622 cu. in. and 14:71 BDS............
Attached Thumbnails Big cubic inches or supercharger?-1ae9_3.jpeg   Big cubic inches or supercharger?-1892_3.jpeg
36spectre is offline
Old 07-24-2007 | 06:51 PM
I found a set of 632 c.i. @725hp
They are N/A big cube motors.. is the weight difference substantial between a motor this size and a supercharged 502 or 454?
Old 07-24-2007 | 07:10 PM
tblrklakemo's Avatar
SeaRay Sundancer
I would rather some 600+cu N/A motors that make at least 750hp. Dry exhaust.
tblrklakemo is offline
Old 07-24-2007 | 07:15 PM
MitchStellin's Avatar
There is no replacement for displacement. Go natural, force feeding an engine air and fuel makes it sick and when it gets sick it barfs......metal.
MitchStellin is offline
Old 07-24-2007 | 07:20 PM
nocigarette's Avatar
They dont make a tunnel ram intake that sounds or looks like a big stupid intercooled roots blower................All motors break parts...............
nocigarette is offline
Old 07-24-2007 | 07:25 PM
dkwestern's Avatar
Big Cubes
dkwestern is offline
Old 07-24-2007 | 07:26 PM
Do both 600 ci with 16-71's The way it works is a supercharger makes things like head ports & monster cam lift less important. Also a proper set-up supercharged motor makes more mid range power & makes at least the same if not more top end power. A blower is a cure all for a motor you don't have to depend on vacuum it's forced. The down side is you can not get cheap on the short block assembly you must have good parts down in the boules of the motor or it will find the weak link & more than likely you'll get to look at it laying in the bottom of the bilge.
allfiredup is offline
Old 07-24-2007 | 07:57 PM
Big cube motors will eat bravos like candy...
If they are tall decks with maybe some raised port heads you might have center line issues to worry about.
Back4More is offline
